• Release notes
  • Concepts
    • SnapCenter role-based access control (RBAC)
  • SnapCenter Server installation
    • Prepare for installing the SnapCenter Server
      • Multi-factor authentication (MFA)
    • Configure CA Certificate for Windows host
    • Configure and enable two-way SSL communication on Windows host
    • Configure and enable two-way SSL communication on Linux host
    • Configure Certificate-based Authentication
      • Import CA Certificate to the UNIX host plug-ins and configure root or intermediate certificates to SPL trust-store
    • Configure Active Directory, LDAP, and LDAPS
    • Configure High Availability
    • Configure role-based access control (RBAC)
    • Provision your storage system
      • Provision storage on Windows hosts
  • Protect Microsoft SQL Server databases
    • SnapCenter Plug-in for Microsoft SQL Server
      • Backup strategy for SQL Server resources
      • Restoration strategy for SQL Server
    • Prepare to install the SnapCenter Plug-in for Microsoft SQL Server
      • Install SnapCenter Plug-in for Microsoft SQL Server
      • Configure Disaster recovery
    • Prepare for data protection
    • Back up SQL Server database, or instance, or availability group
    • Restore SQL Server resources
    • Clone SQL Server database resources
  • Protect SAP HANA databases
    • SnapCenter Plug-in for SAP HANA Databases
      • Backup strategy for SAP HANA databases
      • Restore and recovery strategy for SAP HANA databases
    • Prepare to install the SnapCenter Plug-in for SAP HANA Database
      • Install the SnapCenter Plug-in for SAP HANA Databases
    • Back up SAP HANA resources
      • Discover resources and prepare multitenant database containers for data protection
    • Restore SAP HANA Databases
    • Clone SAP HANA resource backups
  • Protect Oracle databases
    • Overview of SnapCenter Plug-in for Oracle Database
    • Install SnapCenter Plug-in for Oracle Database
    • Back up Oracle databases
      • Backup configuration information
      • Other back up operations
    • Restore and recover Oracle databases
    • Clone Oracle database
    • Manage application volumes
      • Backup application volumes
  • Protect Windows file systems
    • SnapCenter Plug-in for Microsoft Windows concepts
    • Install SnapCenter Plug-in for Microsoft Windows
      • Configure CA certificate
    • Back up Windows file systems
    • Restore Windows file systems
    • Clone Windows file systems
  • Protect Microsoft Exchange Server databases
    • SnapCenter Plug-in for Microsoft Exchange Server concepts
    • Install SnapCenter Plug-in for Microsoft Exchange Server
    • Back up Exchange resources
    • Restore Exchange resources
  • Protect IBM Db2
    • SnapCenter Plug-in for IBM Db2
      • Backup strategy for IBM Db2
      • Restore and recovery strategy for IBM Db2
    • Prepare to install the SnapCenter Plug-in for IBM Db2
      • Install the SnapCenter Plug-in for IBM Db2
    • Back up IBM Db2 resources
    • Restore IBM Db2
    • Clone IBM Db2 resource backups
  • Protect PostgreSQL
    • SnapCenter Plug-in for PostgreSQL
      • Backup strategy for PostgreSQL
      • Restore and recovery strategy for PostgreSQL
    • Prepare to install the SnapCenter Plug-in for PostgreSQL
      • Install the SnapCenter Plug-in for PostgreSQL
    • Back up PostgreSQL resources
    • Restore PostgreSQL
    • Clone PostgreSQL resource backups
  • Protect MySQL
    • SnapCenter Plug-in for MySQL
      • Backup strategy for MySQL
      • Restore and recovery strategy for MySQL
    • Prepare to install the SnapCenter Plug-in for MySQL
      • Install the SnapCenter Plug-in for MySQL
    • Back up MySQL resources
    • Restore MySQL
    • Clone MySQL resource backups
  • Protect applications using NetApp supported plug-ins
    • NetApp supported plug-ins
      • Backup strategy for NetApp supported plug-ins
    • Prepare to install NetApp supported plug-ins
      • Install the NetApp supported plug-ins
    • Back up NetApp supported plug-ins resources
    • Restore NetApp supported plug-ins resources
    • Clone NetApp supported plug-ins resource backups
  • Protect Unix file systems
    • Install SnapCenter Plug-in for Unix file systems
    • Back up Unix file systems
    • Restore and recover Unix file systems
    • Clone Unix file systems
  • Protect applications running on Azure NetApp Files
    • Install SnapCenter and create credentials
  • Manage SnapCenter Server and plug-ins
    • View dashboard
  • Upgrade SnapCenter Server and plug-ins
  • Tech refresh
  • Uninstall SnapCenter Server and plug-ins
    • Uninstall SnapCenter plug-in packages
  • Automate using REST APIs
