SnapCenter software
Define a restore and recovery strategy for SAP HANA resources
You must define a strategy before you restore and recover your database so that you can perform restore and recovery operations successfully.
Steps
  1. Determine the restore strategies supported for manually added SAP HANA resources
  2. Determine the restore strategies supported for auto discovered SAP HANA databases
  3. Decide the type of recovery operations that you want to perform.
