Types of restore strategies supported for manually added SAP HANA resources
Contributors netapp-asubhas Download PDF of this page
You must define a strategy before you can successfully perform restore operations using SnapCenter. There are two types of restore strategies for manually added SAP HANA resources. You cannot recover manually added SAP HANA resources.
Note You cannot recover manually added SAP HANA resources.
Complete resource restore
  • Restores all volumes, qtrees, and LUNs of a resource
Note If the resource contains volumes or qtrees, the Snapshot copies taken after the Snapshot copy selected for restore on such volumes or qtrees are deleted and cannot be recovered. Also, if any other resource is hosted on the same volumes or qtrees, then that resource is also deleted.
File level restore
  • Restores files from volumes, qtrees, or directories
  • Restores only the selected LUNs
