Cancel Oracle database clone operations
Contributors netapp-soumikd Download PDF of this page
You can cancel clone operations that are queued.
You should be logged in as the SnapCenter Admin or job owner to cancel clone operations.
About this task
  • You can cancel a clone operation from either the Monitor page or the Activity pane.
  • You cannot cancel a running clone operation.
  • You can use the SnapCenter GUI, PowerShell cmdlets, or CLI commands to cancel the clone operations.
  • If you selected All members of this role can see and operate on other members objects in Users\Groups page while creating a role, you can cancel the queued backup operations of other members while using that role.
Step
Perform one of the following actions:
From the…​ Action
Monitor page
  1. In the left navigation pane, click Monitor > Jobs.
  2. Select the operation, and click Cancel Job.
Activity pane
  1. After initiating the clone operation, click activity pane icon on the Activity pane to view the five most recent operations.
  2. Select the operation.
  3. In the Job Details page, click Cancel Job.
