Command syntax for disconnecting LUNs and storage entities from the host
To use the snapdrive storage disconnect command to remove the mappings for the LUNs with storage entities, use the following syntax:
snapdrive storage disconnect { -dg | -fs | -hostvol } file_spec [file_spec…] [{ -dg | -fs | -hostvol } file_spec [file_spec…] …] [-full] [-fstype type] [-vmtype type]
