The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version. Command to use to rename a Snapshot copy 01/20/2021 Contributors Suggest changes Create a GitHub issue Send us an email PDFs PDF of this doc site Collection of separate PDF docs Creating your file... This may take a few minutes. Thanks for your patience. Cancel Your file is ready OK Use the snapshot snap rename command to rename a Snapshot copy.
