Configuring sd-admin in Operations Manager console
PDF of this doc site
Administration for Linux
Role-based access control in SnapDrive for UNIX
Installation and Administration for Solaris
Creating and using Snapshot copies in SnapDrive for UNIX
Installation and Administration for IBM AIX
Creating your file...
The Operations Manager console administrator can create the sd-admin user.
The Operations Manager console administrator creates a user named, sd-admin, with the capability to perform a core access check on global group (global DFM.Core.AccessCheck
). After the Operations Manager console administrator configures the sd-admin user, you must manually send the credential information to the SnapDrive for UNIX administrator. For more information about using Operations Manager console to configure users and roles, see the Operations Manager Console Administration guide and the Online Help.
You can use any name in place of sd-admin; however, it is best to use sd-admin. |
To create a role in Operations Manager console, select Setup > Roles. In the sd-admin configuration page, the Operations Manager console administrator must assign DFM.Database.Write
capability on the global group to sd-admin-role, so that SnapDrive for UNIX can refresh storage entities in Operations Manager console.
