Connecting multiple storage entities
Download PDF of this page
You can connect a Snapshot copy containing multiple storage entities.
To connect a Snapshot copy that contains storage entities that reside on multiple destination storage systems you must meet the following requirements:
The storage entities you specify at the command prompt must reside on a single storage system, or on a HA pair.
The name of the volume of the source storage system must match the name of the volume of the destination storage system.
You must set the
snapmirror-dest-multiple-filervolumes-enabled
variable in the snapdrive.conf file to “on”.
You can use one command to connect storage entities that reside on a single storage system or on a HA pair.
