Contents of AutoSupport messages
AutoSupport messages contain the following information.
Event source
Event ID
Version of SnapDrive for UNIX
Message status: Log level messages, for example 1 for alert, 2 for critical, 3 for error, 4 for warning, 5 for notice, 6 for information, and 7 for debug
Host name
Host operating system
Release version of the host operating system
Name of the storage system
Usage of Protection Manager/Role Based Access Control
Error category
AutoSupport Flag message entry as FALSE
Host multipathing type: The value configured in
snapdrive.conffile is logged. If the assistant is not loaded due to incorrect configuration value, no host multipathing type is logged. -
Host virtualization enabled: This is captured only for VMware guest operating system.
Protocol: The value configured for
default-transportin thesnapdrive.conffile. -
Protection enabled: If OnCommand Data Fabric Manager (DFM) is configured with SnapDrive for UNIX, the value Yes is logged.
SnapDrive for UNIX does not verify whether OnCommand DFM is in use.
The following additional information is available when you run the snapdrive storage show -all command:
Type of protocols (FCP/iSCSI): Protocols used to create the luns, if any.
Number of connected LUNs
Number of disk or volume groups
Number of file specifications
Number of host volumes
When AutoSupport is enabled in SnapDrive for UNIX, upon any operation failures, the error messages are logged in the Event Management System (EVM) storage system. If the error message contains any special characters such as (<, >, &, ', ", \r), garbled values are displayed in the EMS log view of the storage system. |
