Determining how many LUNs can be created
SnapDrive for UNIX lets you determine how many LUNs can be created on the host without exceeding the limit.
You can use snapdrive config check luns command to determine this value.
On a Linux host, this command checks the existing /dev/sg files to determine how many are unused.
