Disconnecting a file specification
You can disconnect a file specification. The following example describes how you can complete this operation.
The layout of /mnt/fs1_0 is given in the following.
# snapdrive storage show -fs /mnt/fs_1_0 -capabilities raw device: /dev/sde1 mount point: /mnt/fs_1_0 (persistent) fstype ext3 allowed operations: all device filename adapter path size proto state clone lun path backing snapshot ---------------- ------- ---- ---- ----- ----- ----- -------- ---------------- /dev/sde - P 100m iscsi online flex-clone homer:/vol/Snapdrive_vol1_volume_clone_from_snap2_snapshot/lun1 vol1:snap2
The following output shows how to disconnect the file system /mnt/fs_1_0:
#snapdrive snap disconnect -fs /mnt/fs_1_0
delete file system /mnt/fs_1_0
- fs /mnt/fs_1_0 ... deleted
- LUN homer:/vol/Snapdrive_vol1_volume_clone_from_snap2_snapshot/lun1 ... disconnected
- deleting volume clone ... homer:/vol/Snapdrive_vol1_volume_clone_from_snap2_snapshot done
After disconnecting the file system /mnt/fs_1_0, SnapDrive for UNIX also deletes the cloned volume Snapdrive_vol1_0_volume_clone_from_snap2_snapshot, if the following conditions are met:
No mapped LUNs are present in the volume
No new LUNs are present
No new Snapshot copies are present
Deleting a FlexClone not created by SnapDrive for UNIX: SnapDrive for UNIX does not allow deletion of FlexClone not created by it.
