Guidelines for deleting Snapshot copies
PDF of this doc site
Administration for Linux
Role-based access control in SnapDrive for UNIX
Installation and Administration for Solaris
Creating and using Snapshot copies in SnapDrive for UNIX
Installation and Administration for IBM AIX
Creating your file...
Your file is ready
You cannot delete a Snapshot copy that is in use, or if the Snapshot copy is across multiple storage system volumes.
Follow these guidelines when you use the snapdrive snap delete
command:
The Snapshot delete operation fails if any of the Snapshot copies you want to delete are in use, or not created by SnapDrive for UNIX. You can override this behavior by including the
-force
option with thesnapdrive snap delete
command. -
If you have a Snapshot copy that spans multiple storage system volumes, you must manually delete the Snapshot copy on each volume.
