Managing Snapshot copies using a wizard
Download PDF of this page
You can use a wizard to manage Snapshot copies. This wizard runs you through a set of questions and helps you to perform the snap connect, snap restore, and snap disconnect operations.
You can run the wizard by using the snapdrive snap wizard
command.
The following table lists the different operations and corresponding commands to run the wizard. After launching the wizard, follow the steps in the application window.
Operation | Command |
Snapshot restore |
Snapshot connect |
Snapshot connect operation for file system with storage system volume |
Snapshot connect for disk group |
Snapshot disconnect for LUN |
Snapshot disconnect for a disk group |
Snapshot disconnect for host volume |
Snapshot disconnect for file system |
Limitations: In SnapDrive for UNIX 4.1 and later, the snapdrive snap wizard
command has the following limitations:
Volume-based SnapRestore is not supported with the
snap wizard restore
command. -
FlexClone® volume is not supported with the
snap wizard connect
command. -
Operations on unresponsive file specifications are not supported with
snap wizard
commands.
