Role-based access control for FlexClone volume operations
If Operations Manager is configured with the system, the Operations Manager administrator must grant you the required capabilities to carry out storage operations on FlexClone volumes.
Unrestricted FlexClone volume: You must have the following capabilities to perform storage operations on an unrestricted FlexClone volume:
For
snap connect, you must haveSD.SnapShot.UnrestrictedClonecapability on the parent volume. -
For
snap disconnect, you must haveSD.SnapShot.DestroyUnrestrictedClonecapability on the FlexClone volume.
Restricted FlexClone volumes: You must have the following capabilities for storage operations on a restricted FlexClone volume:
For
snap connectyou must haveSD.SnapShot.Clonecapability on the parent volume. -
For
snap disconnectyou must haveSD.SnapShot.Clonecapability on the parent volume.
To split the FlexClone volume during the snap connect operation, SD.Storage.Write access capability on the parent volume.
To perform storage operations on split FlexClone volumes during the snap disconnect, for split FlexClone volumes, you must have SD.Storage.Delete capability on the split volume clone.
