snapdrived start command fails
In some conditions snapdrived start
command may fail. There are a few troubleshooting steps to resolve this.
Check whether daemon port specified in
snapdrive.conf
file is already in use by other application. -
Check whether an earlier instance of daemon is stopped properly.
Check whether system-wide semaphore limit is reached, in which case daemon start does not work.
Check whether any of the services like iSCSI, VxVM is not running on the machine.
If HTTPS is set to
on
, check whether self signed certificate is installed in the specified directory.
