Snapshot create and delete operation fails
The Snapshot create and delete operation fails to remove Snapshot copies on the storage system because the LUNs are busy.
The following error message appears:
0001-124 Admin error: Failed to remove snapshot <snap-name> on filer <filer-name>: LUN clone
You might encounter this error and might not be able to directly delete a Snapshot copy if the following are true:
A disk group spans across multiple storage systems.
The following SnapDrive commands are executed in a loop for more than 50 iterations (the number of iterations depends on the host operating system):
snapdrive storage create -
snapdrive snap create -
snapdrive storage delete -
snapdrive snap restore -
snapdrive snap connect -
snapdrive snap delete
At this point, the Snapshot copy status on the storage system shows LUNs-Busy, and this status prolongs for a few hours.
Workaround
| If… | Then… | ||
There are cloned LUNs in a Snapshot copy that are not connected to a host. |
You can do one of the following to delete the Snapshot copy:
Do the following steps:
There are any of the following:
Complete the following steps:
There are no cloned LUNs |
Wait until the |
