Tasks performed by snapdrive.dc
The data collection utility runs the NetApp diagnostic utilities, copies SnapDrive for UNIX log files, and creates a compressed file that is used for analysis.
The snapdrive.dc utility performs the following tasks:
Runs the
host_infoandfiler_infoutilities to collect information about the host and the storage systems connected to the host, and saves this information in a compressed file. Thehost_infoutility andfiler_infoutility comes along with SnapDrive for UNIX installation package.For example, on Linux, it is the
linux_infoutility. -
Creates a directory called /tmp/netapp/ntap_snapdrive_name. The tool places copies of the following files in the directory:
SnapDrive for UNIX version, as indicated by running the snapdrive version command
The
snapdrive.conffile -
The audit log files
The trace log files
The recovery log files
The files created by the host_info utility
Creates a compressed file of the directory contents and displays a message stating you send this file toNetApp technical support.
Related information
