General notes about the commands
SnapDrive for UNIX commands have options such as -dg, -vg, -lvol and -hostvol.
Some general notes about the command follow:
The
-dgand-vgoptions are synonyms that reflect the fact that some operating systems refer to disk groups and others refer to volume groups. This guide uses -dg to refer to both disk groups and volume groups. -
The
-lvoland-hostvoloptions are synonyms that reflect the fact that some operating systems refer to logical volumes and others refer to host volumes. This guide uses-hostvolto refer to both logical volumes and host volumes. -
It is better to use the default igroup and not specify an igroup explicitly by including the
-igroupoption.
