The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version .
Storage provisioning command lines
01/21/2021
Some SnapDrive for UNIX commands are used for storage provisioning.
The following command-line options are used for storage-provisioning operations:
Operation
Command-line option
snapdrive storage create -lun long_lun_name [lun_name …] -lunsize size [{ -dg | -vg } dg_name ] [-igroupig_name [ig_name … ]] [{ -reserve | -noreserve }][-fstype type ] [-vmtype type ]
snapdrive storage create {-lvol | -hostvol} file_spec [{-dg | -vg} dg_name ]{-dgsize | -vgsize} size -filervol long_filer_path [{-noreserve | -reserve}] [-fstype type ] [-vmtype type ]
snapdrive storage create -fs file_spec -nolvm [-fsopts options ] [-mntopts options] [-nopersist] { -lun long_lun_name | -filervol long_filer_path } -lunsize size [-igroup ig_name [ig_name … ]] [{ -reserve | -noreserve }] [-fstype type ] [-vmtype type ]
snapdrive storage create host_lvm_fspec -filervol long_filer_path -dgsize size [-igroup ig_name [ig_name … ]] [{ -reserve | -noreserve }]
snapdrive storage create host_lvm_fspec -lun long_lun_name [lun_name … ] -lunsize size [-igroupig_name [ig_name …]] [{ -reserve | -noreserve }]
You can use any one of the format for the -file_spec argument, depending on the type of storage you want to create. (Remember that -dg is a synonym for -vg, and -hostvol is a synonym for -lvol.)
To create a file system directly on a LUN, use this format: -fs file_spec [-nolvm -fs type ] [-fsops options ] [-mntopts options ] [-vmtype type ]
To create a file system that uses a disk group or host volume, use this format: -fs file_spec [-fstype type ] [-fsopts options ] [-mntops options ] [-hostvol file_spec ] [-dg dg_name ] [-vmtype type ]
To create a logical or host volume, use this format: [-hostvol file_spec ] [-dg dg_name ] [-fstype type ] [-vmtype type ]
To create a disk group, use this format: -dg dg_name [-fstype type ] [-vmtype type ]
snapdrive storage connect -fs file_spec -nolvm -lun long_lun_name [-igroup ig_name [ig_name … ]] [-nopersist] [-mntopts options] [-fstype type ] [-vmtype type ]
snapdrive storage connect -fs file_spec -hostvol file_spec -lun long_lun_name [lun_name … ] [-igroup ig_name [ig_name … ]][-nopersist] [-mntopts options] [-fstype type ] [-vmtype type ]
snapdrive storage connect -lun long_lun_name [lun_name … ][-igroup ig_name [ig_name … ]][-vmtype type ]
snapdrive storage connect -lun long_lun_name [lun_name… ][-vmtype type ]
snapdrive storage connect -fs file_spec {-hostvol | -lvol} file_spec -lun long_lun_name [lun_name… ] [-nopersist] [-mntopts options] [-fstype type ] [-vmtype type ]
snapdrive storage disconnect -lun long_lun_name [lun_name… ] [-vmtype type ]
snapdrive storage disconnect {-vg | -dg | -fs | -lvol | -hostvol} file_spec [file_spec … ] [{-vg | -dg | -fs | -lvol | -hostvol} file_spec …] …] [-full] [-fstype type ] [-vmtype type ]
snapdrive storage resize {-dg | -vg} file_spec [file_spec … ]{-growby | -growto} size [-addlun [-igroup ig_name [ig_name … ]]] [{ -reseserve | -noreserve }]] [-fstype type ] [-vmtype type ]
snapdrive storage { show | list } -filer filername [filername … ] [-verbose] [-quiet] [-capabilities]
snapdrive storage { show | list } -filervol long_filer_path [filer_path… ][-verbose] [-quiet] [-capabilities]
snapdrive storage { show | list } {-all | device} [-capabilities]
snapdrive storage show [-verbose] {-filer filername [filername… ] | -filervol volname [volname… ]} [-capabilities]
snapdrive storage { show | list } -lun long_lun_name [lun_name … ] [-verbose] [-quiet] [-status] [-capabilities]
snapdrive storage { show | list } { -vg | -dg | -fs | -lvol |-hostvol } file_spec [file_spec … ] [{ -vg | -dg | -fs | -lvol | -hostvol } file_spec [file_spec … ]] [-verbose] [-quiet [-fstype type ] [-vmtype type ] [-status] [-capabilities]
snapdrive storage { show | list } { -filer filer_name [filer_name … ] | -filervol long_filer_path [filer_path … ] } [-verbose] [-capabilities] [-quiet]
snapdrive storage { show | list } -lun long_lun_name [lun_name … ] [-verbose] [-status] [-fstype type] [-vmtype type] [-capabilities] [-quiet]
snapdrive storage delete [-lun] long_lun_name [lun_name…] [-fstype type] [-vmtype type]
snapdrive storage delete [-vg | -dg | -fs | -lvol | -hostvol] file_spec [file_spec …] [{-vg | -dg | -fs | -lvol | -hostvol} file_spec [file_spec …] …] [-full] ] [-fstype type] [-vmtype type]
