Connecting to Snapshot copies of shared storage entities other than LUNs
You can use the snapdrive snap connect command to connect to a Snapshot copy of shared storage entities other than LUNs.
Steps
Enter the following command:
snapdrive snap connect fspec_set [fspec_set…] -snapname long_snap_namefspec_set [fspec_set…] -snapname long_snap_name [-devicetype shared] [-split]In this syntax,
fspec_setis:{-dg | -fs} src_file_spec [dest_file_spec ] [-destdg dgname]`
