Deleting a data interface entry for a management interface
You can delete a data interface entry that is associated with a specific management interface in an NFS environment by using the snapdrive config delete -mgmtpath command.
Steps
At the CLI, enter the following command:
snapdrive config delete -mgmtpath data_interface#snapdrive config delete –mgmtpath f3050-197-91 Deleted configuration for appliance: f3050-197-91
The following is an example for Vserver.
#snapdrive config delete –mgmtpath clstr-vs2 Deleted configuration for appliance: clstr-vs2
