Disconnecting Snapshot copies with shared storage entities
You can use the snapdrive snap disconnect command to disconnect a Snapshot copy that contains shared storage entities.
Steps
Enter the following command syntax:
snapdrive snap disconnect {-dg | -fs} file_spec [file_spec…] {-dg | -fs} file_spec [file_spec…]…] long_snap_name [-full] [-fstype type] [-vmtype type] [-split]
This example disconnects shared file system:
# snapdrive snap disconnect -fs /mnt/oracle
