Forcing daemon restart
You can force the daemon to restart. A forceful restart of the daemon stops the execution of all running commands.
Ensure that you are logged in as a root user.
Steps
Enter the following command to forcefully restart the daemon:
snapdrived -force restartAfter the force restart request is received, the daemon stops all the commands in execution and in queue. The daemon is restarted only after cancelling execution of all running commands.
