Receiving error iscsi64 snapdrive: 0001-666 FATAL error
If your snapdrive snap connect command fails with iscsi64 snapdrive: 0001-666 FATAL error:, following is the workaround described.
Steps
Add
filter = [ "r|/dev/cciss/.*|" ]as the first filter to/etc/lvm/lvm.conffile, if the filter is not specified already. -
Remove
/etc/lvm/.cacheand issuepvscanto confirm that none of the/dev/cciss/*entries show.
