Snap disconnect operation fails to delete cloned volume
Download PDF of this page
In some cases, snapdrive snap disconnect
operation fails to delete cloned volume and the error message does not look SnapDrive-generated
appears.
The workaround for the problem is to revert to the original name of the Snapshot copy, and ensure that the bypass-snapdrive-clone-generated-check
is set to on in the snapdrive.conf
file.
