Snapdrive for Unix
Removing a port set from SnapDrive
Contributors netapp-ivanad
You can use the snapdrive portset delete command to delete a port set that is configured in SnapDrive.
Steps
  1. Enter the following command on the host system:
    snapdrive portset delete filername [filername…​]
    filername is the Vserver name on which the port set is configured.
    snapdrive portset delete vs91
    Deleted portset configuration for appliance: vs91
    The port set that is configured for SnapDrive is removed successfully.
