Setting up HTTP
You can configure SnapDrive for UNIX to use HTTP for your host platform.
Ensure that you are logged in as a root user.
Steps
Make a backup of the
snapdrive.conffile. -
Open the
snapdrive.conffile in a text editor. -
Change the value of the
use-https-to-filervariable to off.A good practice any time you modify the
snapdrive.conffile is to perform the following steps:-
Comment out the line you want to modify.
Copy the commented-out line.
Un-comment the copied text by removing the pound (#) sign.
Modify the value.
Save the file after you make your changes.
SnapDrive for UNIX automatically checks this file each time it starts. You must restart the SnapDrive for UNIX daemon for the changes to take effect.
