Installing SnapDrive for UNIX
You can install SnapDrive for UNIX on the Linux host from the command-line interface.
Steps
Download the SnapDrive for UNIX for Linux installer from the NetApp Support Site NetApp Downloads: Software and copy the file to the Linux host.
Log in to the host system as the root user.
If you are running the installer file remotely and if the system configuration does not allow you to log in as the root user, use the
sucommand to log in as root user. -
Navigate to the directory on your Linux host to which you have copied the installer.
Install SnapDrive for UNIX:
rpm-ivh installer_file_name
The SnapDrive daemon starts automatically after the installation.
Starting snapdrive daemon: Successfully started daemon
