The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version. Configure hosts 05/19/2022 Suggest changes Create a GitHub issue Send us an email PDFs PDF of this doc site Collection of separate PDF docs Creating your file... This may take a few minutes. Thanks for your patience. Cancel Your file is ready OK You can add, view, and remove Hyper-V parent hosts or clusters by using SnapManager for Hyper-V.
