SnapManager for Hyper-V
Manage reports
You can view and delete backup, restore, and configuration reports in SnapManager for Hyper-V. These reports contain important information about your datasets, virtual machines, and hosts. You can also export reports in several different formats.
  • Backup reports
    Backup reports display all of the backup information for all hosts belonging to a particular dataset. You can view a backup report for either a dataset or a virtual machine. Reports displayed for a virtual machine use the virtual machine name instead of its GUID.
    When the backup report is displayed, you can export it into several different formats.
  • Restore reports
    Restore reports display all of the information about the restore operation on a per-VM basis.
    When the restore report is displayed, you can export it into several different formats.
  • Configuration reports
    Configuration reports display the notification settings, report path, and SnapInfo path for the selected host.
    When the configuration report is displayed, you can export it into several different formats.
