Vss Requestor - Backup Components failed with partial writer error
Message
Error: Vss Requestor - Backup Components failed with partial writer error. Writer Microsoft Hyper-V VSS Writer involved in backup or restore operation reported partial failure. Writer returned failure code 0x80042336. Writer state is 5. Application specific error information: Application error code: 0x1 Application error message: - Failed component information: Failed component: VM GUID XXX Writer error code: 0x800423f3 Application error code: 0x8004230f Application error message: Failed to revert to VSS snapshot on the virtual hard disk 'volume_guid' of the virtual machine 'vm_name'. (Virtual machine ID XXX)The following errors appear in the Windows Application event log on the Hyper-V host:
Volume Shadow Copy Service error: Unexpected error calling routine GetOverlappedResult. hr = 0x80070057, The parameter is incorrect. Operation: Revert a Shadow Copy Context: Execution Context: System Provider Volume Shadow Copy Service error: Error calling a routine on a Shadow Copy Provider {b5946137-7b9f-4925-af80-51abd60b20d5}. Routine details RevertToSnapshot [hr = 0x80042302, A Volume Shadow Copy Service component encountered an unexpected error. Check the Application event log for more information.]. Operation: Revert a Shadow Copy Context: Execution Context: Coordinator -
This message appears when performing an application-consistent backup of a dataset. This error causes the backup to fail for some of the virtual machines in the dataset.
Corrective action
Retry the dataset backup.
If the retry attempt fails again, split the dataset into two datasets so that all the VMs whose backup failed will be placed into a single dataset and all other VMs will be put into another dataset. Then run the backup again.
