Either the specified VM(s) are not present or they cannot be backed up online
Message
Either the specified VM(s) are not present or they cannot be backed up online -
One reason this message occurs is when application-consistent backups fail if the pass-through disk size on the VM is less than 300 MB. Your error log will resemble the following example:
Log Name: Application Source: SnapMgrServiceHost Date: 11/12/2012 12:24:28 PM Event ID: 106 Task Category: Backup Event Level: Error Keywords: Classic User: N/A Computer: defiant16.wak-qa.com Description: SnapManager for Hyper-V backup failed to complete Backup Failed for the following VM(s) since it cannot be backedup online or No VM to be found for backup VM Name: demovm-0There are no other application or system error messages to indicate the failure.
Corrective action
You can either resize the pass-through disk to be larger than 300 MB or run the backup with the Allow saved state VM backup option enabled.
This corrective action is applicable in both SAN and NAS environments. -
Message
A second reason this message occurs is because Windows cannot perform an online backup of this system because the scoped snapshots option for Hyper-V VMs is enabled. Scoped snapshots are mainly used by Windows critical updates.
Corrective action
You must disable the
scoped snapshotsoption by creating a DWORDScopeSnapshotsparameter with value 0 in:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\SystemRestore\This corrective action is applicable in both SAN and NAS environments.
