SnapManager for Hyper-V is not licensed on the host or in the Storage System
Message
SnapManager for Hyper-V is not licensed on the host or in the Storage System, backup is aborted -
This message occurs either when your system is not licensed or when there are issues with enumeration, virtual machine caching, or master boot record (MBR) disk use.
Corrective action
Ensure that your system is licensed.
Migrate any MBR disks, which SnapManager for Hyper-V does not support, to GUID Partition Table (GPT) disks.
Restart SnapManager for Hyper-V. If this does not resolve the issue, you most likely have an enumeration problem and should contact technical support.
