Web Service Client channel was unable to connect to the ConfigurationManagementService instance on machine smhv51_81clus
Message
Web Service Client channel was unable to connect to the ConfigurationManagementService instance on machine smhv51_81clus.There was no endpoint listening at net.tcp://smhv51_81clus/SnapManager/HyperV/ConfigMgmtService/v_10 that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details. -
If you export configuration information, the local Web service port settings of the managed hosts are stored in the exported configuration file. If you later have to reinstall SnapManager for Hyper-V using a different Web service port, and import the former configuration information, you experience connection issues.
Corrective action
To prevent this issue, use the same Web service port settings contained in the exported configuration file when reinstalling SnapManager for Hyper-V.
