Delete a report
You can delete one or more reports when they are no longer necessary.
Steps
From the navigation pane, click or .
Select the dataset, virtual machine, or host that contains the report or reports you want to delete.
From the Reports pane, select the report or reports you want to delete.
From the Actions pane, click Delete report and click OK to delete.
