Remove a Hyper-V parent host or parent host cluster
You can remove a Hyper-V parent host or parent host cluster when you no longer want to manage it using SnapManager for Hyper-V.
Steps
From the navigation pane, click .
Select the host or host cluster you want to remove.
In the Actions pane, click Remove.
You can select Delete all VM backups to delete any virtual machine backups associated with the host.
The Hyper-V parent host or host cluster is removed from SnapManager for Hyper-V management but is not deleted permanently. The virtual machines belonging to that host or host cluster are also removed from any datasets to which they belonged.
