Verify that the VSS Hardware Provider was used successfully
You can verify that the Data ONTAP VSS Hardware Provider was used successfully after a Snapshot copy was made.
Steps
Navigate to in MMC and look for an event with the following values:
Source Event ID Description Navssprv
4089
The VSS provider has successfully completed CommitSnapshots for SnapshotSetId id in n milliseconds.
VSS requires that the provider commit a Snapshot copy within 10 seconds. If this time limit is exceeded, the Data ONTAP VSS Hardware Provider logs Event ID 4364. This limit could be exceeded due to a transient problem. If this event is logged for a failed backup, retry the backup. |
