SnapManager Oracle
Variables available in the task scripts for the restore operation
SnapManager provides context information in the form of environment variables related to the restore operation that is being performed. For example, your script can retrieve the name of the original host and the label of the backup that is restored.
The following table lists the environment variables that you can use in your scripts:
Variables Description Format
SM_OPERATION_ID
Specifies the ID of the current operation
string
SM_PROFILE_NAME
Specifies the name of the profile used
string
SM_HOST
Specifies the host name of the database
string
SM_OS_USER
Specifies the operating system (OS) owner of the database
string
SM_OS_GROUP
Specifies the OS group of the database
string
SM_BACKUP_TYPE
Specifies the type of the backup (online, offline, or auto)
string
SM_BACKUP_LABEL
Specifies the backup label
string
SM_BACKUP_ID
Specifies the backup ID
string
SM_BACKUP_PROFILE
Specifies the profile used for the backup
string
SM_RECOVERY_TYPE
Specifies the recovery configuration information
string
SM_VOLUME_RESTORE_MODE
Specifies the volume restore configuration
string
SM_TARGET_FILER_NAME
Specifies the target storage system name Note: If more than one storage system is used, then the storage system names must be separated by commas.
string
SM_TARGET_VOLUME_NAME
Specifies the target volume name Note: The target volume name must be prefixed with storage device name, for example, SM_TARGET_FILER_NAME/SM_TARGET_VOLUME_NAME.
string
SM_HOST_FILE_SYSTEM
Specifies the host file system
string
SM_SNAPSHOT_NAMES
Specifies the Snapshot list Note: Name of the Snapshot copies must be prefixed with the storage system name and volume name. Names of the Snapshot copies are separated by commas.
string array
SM_ASM_DISK_GROUPS
Specifies the ASM Disk group list
string array
SM_ARCHIVE_LOGS_DIRECTORY
Specifies the archive logs directory Note: If the archive logs are located in more than one directory, then the names of those directories are separated by commas.
string array
SM_REDO_LOGS_DIRECTORY
Specifies the redo logs directory Note: If the redo logs are located in more than one directory, then the names of those directories are separated by commas.
string array
SM_CONTROL_FILES_DIRECTORY
Specifies the control files directory Note: If the control files are located in more than one directory, then the names of those directories are separated by commas.
string array
SM_DATA_FILES_DIRECTORY
Specifies the data files directory Note: If the data files are located in more than one directory, then the names of those directories are separated by commas.
string array
