Supported partition devices
You must know the different partition devices that are supported in SnapManager.
The following table provides partition information and how it can be enabled for different operating systems:
| Operating system | Single partition | Multiple partition | Non-partition devices | File system or RAW devices |
Red Hat Enterprise Linux 5x or Oracle Enterprise Linux 5x |
Yes |
No |
No |
ext3* |
Red Hat Enterprise Linux 6xor Oracle Enterprise Linux 6x |
Yes |
No |
No |
ext3 or ext4* |
SUSE Linux Enterprise Server 11 |
Yes |
No |
No |
ext3* |
SUSE Linux Enterprise Server 10 |
No |
No |
Yes |
ext3*** |
Red Hat Enterprise Linux 5x or lateror Oracle Enterprise Linux 5x or later |
Yes |
No |
Yes |
ASM with ASMlib** |
SUSE Linux Enterprise Server 10 SP4or SUSE Linux Enterprise Server 11 |
Yes |
No |
Yes |
ASM with ASMlib** |
SUSE Linux Enterprise Server 10 SP4 or lateror SUSE Linux Enterprise Server 11 |
Yes |
No |
No |
ASM without ASMlib** |
For more information on the operating system versions supported, refer to the Interoperability Matrix.
