SnapManager Oracle
The smo notification remove-summary-notification command
This command disables summary notification for multiple profiles on a repository database.
Syntax
-repository
-dbname repo_service_name
-port repo_port
-host repo_host
-login -username repo_username
\[-quiet \| -verbose\]
  • -repository
    The options that follow -repository specify the details of the database for the repository.
  • -port repo_port
    Specifies the TCP port number used to access the database that stores the repository.
  • -dbname repo_service_name
    Specifies the name of the database that stores the repository. Use either the global name or the SID.
  • -host repo_host
    Specifies the name or IP address of the host computer the repository database runs on.
  • -login repo_username
    Specifies the login name needed to access the database that stores the repository.
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
The following example disables summary notification for multiple profiles on a repository database.
smo notification remove-summary-notification –repository –port 1521 –dbname repo2 –host 10.72.197.133 –login -username oba5
