The smo repository rolling upgrade command
This command performs rolling upgrade on a single host or multiple hosts and their associated target databases from a lower version of SnapManager to a higher version. The upgraded host is managed only with the higher version of SnapManager.
Syntax
smo repository rollingupgrade -repository -dbname repo_service_name -host repo_host -login -username repo_username -port repo_port -upgradehost host_with_target_database [-force] [-noprompt] \[-quiet \| -verbose\]
-repository
The options that follow -repository specify the details of the database for the repository.
Specifies the name of the database that stores the repository. Use either the global name or the SID.
-host repo_host
Specifies the name or IP address of the host computer the repository database runs on.
-login
Starts the repository login details.
Specifies the user name needed to access the database that stores the repository.
Specifies the name of the host which will be rolling upgraded from a lower version of SnapManager to a higher version.
-port repo_port
Specifies the TCP port number used to access the database that stores the repository.
-force
Attempts to force the update of the repository. SnapManager prompts you to make a backup of the current repository before updating.
-noprompt
Does not display the prompt before updating the repository database. Using the -noprompt option ensures the prompt does not appear, making it easier to update repositories using a script.
-quiet
Displays only error messages on the console. The default is to display error and warning messages.
-verbose
Displays error, warning, and informational messages on the console.
Example command
The following example updates the repository in the SALESDB database.
smo repository rollingupgrade -repository -dbname SALESDB -host server1 -login -username admin -port 1521 -upgradehost hostA
