SnapManager Oracle
The smo credential delete command
This command deletes the user credentials for a particular secured resource.
Syntax
\[-host -name host_name
-username username\] \|
[-repository
-dbname repo_service_name
-host repo_host
-login -username repo_username
-port repo_port\] \|
\[-profile
-name profile_name\]
[-quiet | -verbose]
  • -host hostname
    Specifies the name of the host server on which SnapManager is running.
    The -host parameter includes the following options:
    • -name host_name: Specifies the name of the host for which you will delete the password.
    • -username user_name: Specifies the user name on the host.
  • -repository -dbname
    Specifies the name of the database that stores the profile. Use either the global name or the SID.
    The -repository parameter includes the following options:
    • -dbnamerepo_service_name: Specifies the name of the database that stores the profile. Use either the global name or the SID.
    • -host repo_host: Specifies the name or IP address of the host server the repository database runs on.
    • -login-username repo_username: Specifies the user name needed to access the database that stores the repository.
    • -port repo_port: Specifies the TCP port number used to access the database that stores the repository.
  • -profile -name profile_name
    Specifies the profile with which the database is associated.
    The -profile parameter includes the following option:
    • -name profilename: Specifies the name of the profile for which you will delete the password.
  • -quiet
    Displays only error messages on the console. The default is to display error and warning messages.
  • -verbose
    Displays error, warning, and informational messages on the console.
Example command
This example deletes the credentials of the profile.
smo credential delete -profile -name user1 -verbose
SMO-20022 [INFO ]: Deleted credentials and repository mapping
 for profile "user1" in user credentials for "user1".
This example deletes the credentials of the repository.
smo credential delete -repository -dbname SMOREPO -host Host2
-login -username user1 -port 1521
SMO-20023 [INFO ]: Deleted repository credentials for "user1@SMOREPO/wasp:1521"
and associated profile mappings in user credentials for "user1".
This example deletes the credentials of the host.
smo credential delete -host -name Host2
SMO-20033 [INFO ]: Deleted host credentials for "Host2" in user credentials for "user1".
Related information
