SnapManager Oracle
The smo version command
You can run the version command to determine which version of SnapManager you are running on your local host.
Syntax
        smo version
\[-quiet \| -verbose\]
  • -quiet
    Displays only error messages in the console. The default is to display error and warning messages.
  • -verbose
    Displays the build date and contents of each profile. Also displays error, warning, and informational messages in the console.
Example of the version command
The following example displays the version of the SnapManager:
smo version
SnapManager for Oracle Version: 3.3.1
