SnapManager Oracle
Cloning databases and using custom plug-in scripts
SnapManager provides a method for using your custom scripts before and after a clone operation occurs. For example, you might have created a custom script that validates a clone database SID and ensures the SID is allowed by your naming policy. Using the SnapManager clone plug-in, you can include your custom scripts and have them run automatically before or after a SnapManager clone operation.
  1. View sample plug-in scripts.
  2. Create a script from scratch or modify one of the sample plug-in scripts.
    Create your custom script according to SnapManager plug-in script guidelines.
  3. Place your custom script in a specified directory location.
  4. Update the clone specification XML file and include information about your custom script that should be used during the cloning process.
  5. Using a SnapManager command, verify that the custom scripts are operational.
  6. When you initiate the clone operation, include the script name and optional parameters.
