Viewing the status of the clone split process
You can view the progress of the split process you started.
To view the progress of the clone split process, enter the following command:
smo clone split-status -profileprofile [-hosthostname] [-labelsplit-label | -idsplit-id] [-quiet | -verbose]
smo clone split-status -profile p1 -id 8abc01ec0e78f3e2010e78f3fdd00001
