Supported storage types
PDF of this doc site
- Administration for UNIX
- Installation and Administration for Windows
Creating your file...
Your file is ready
SnapManager supports a wide range of storage types on both physical and virtual machines. You must verify support for your storage type before you install or upgrade SnapManager.
Machine | Storage type |
Physical server |
VMware ESX |
