All Clusters View dashboard
On the Dashboard page of the All Clusters View, you can view performance, capacity, and cluster statistic details about the clusters associated with your account.
| Heading | Description |
Company |
Company name assigned to the cluster. |
Cluster |
Name assigned to the cluster. |
Cluster ID |
Assigned cluster number when the cluster is created. |
Version |
Version of the cluster master running on each node. |
Nodes |
Number of nodes in the cluster. |
Volumes |
Number of volumes in the cluster. |
Efficiency |
The amount of efficiency the system is seeing due to compression, deduplication, and thin provisioning. |
Used Block Capacity |
Current used capacity of the cluster block. |
Faults |
Number of currently unresolved faults detected on the cluster. |
SVIP |
Storage virtual IP address assigned to the cluster. |
MVIP |
Management Virtual IP address assigned to the cluster. |
Last Update |
Time and date that the most recent cluster update. |
Actions |
Options to request upgrade support for a cluster, archive a cluster, and suppress a cluster |
If the cluster you are looking for is unavailable, be aware that clusters that have been inactive for 180 days or more are automatically archived. Contact support for further assistance. |
