Nodes head
From the Nodes page, available from the side panel for a selected cluster, you can view information for the nodes in your cluster.
The available details vary based on your system:
View SolidFire storage node details
Each node is a collection of SSDs. Each storage node comes with CPU, networking, cache, and storage resources. The storage node resources are pooled into a cluster of nodes.
On the Nodes page, the information bar provides a quick overview of the following data:
MVIP: Management virtual IP address
MVIP VLAN ID: Virtual LAN ID for the MVIP
SVIP: Storage virtual IP address
SVIP VLAN ID: Virtual LAN ID for the SVIP
View information about storage nodes
The following information is available for each storage node in the cluster:
| Heading | Description |
ID |
System-generated ID for the node. |
Status |
The status of the node:
Name |
The system-generated node name. |
Type |
Displays the model type of the node. |
Platform Config Version |
The config version of the chassis you are running on. |
BIOS Version |
The BIOS version for your node's hardware. |
BMC Firmware Revision |
The revision of the firmware currently running on the Baseboard Management Controller (BMC). |
Version |
Version of Element software running on the node. |
Serial Number |
Unique serial number assigned to the node. |
Management IP |
Management IP address assigned to node for 1GbE or 10GbE network admin tasks. |
Cluster IP |
Cluster IP address assigned to the node used for the communication between nodes in the same cluster. |
Storage IP |
Storage IP address assigned to the node used for iSCSI network discovery and all data network traffic. |
Average Throughput Last 30 mins |
Sum of average throughputs executed in the last 30 minutes against all volumes that have this node as their primary. |
Average IOPS Last 30 mins |
Sum of the average number of IOPS executed in the last 30 minutes against all volumes that have this node as their primary. |
Average Latency (µs) Last 30 mins |
The average time in microseconds, as measured over the last 30 minutes, to complete read and write operations to all volumes that have this node as their primary. To report this metric based on active volumes, only non-zero latency values are used. |
Role |
Identifies what role the node has in the cluster:
End of Availability |
Date when nodes are no longer available for purchase, but are still supported. |
End of Hardware Support |
Date when hardware is no longer supported. |
End of Software Support |
Date when software is no longer supported. |
View NetApp HCI storage and compute node details
For NetApp H-series nodes, which comprise a NetApp HCI system, there are two types: compute and storage nodes.
Learn about viewing information about storage nodes and compute nodes in a NetApp HCI cluster:
Select Storage to view the following information about the storage nodes in the cluster.
ID |
Status |
Name |
Type |
Shows the model type of the node. |
Chassis / Slot |
Unique serial number assigned to the chassis and the slot location of the node. |
Serial Number |
BIOS Version |
Version |
Management IP |
Storage IP |
Role |
View information about compute nodes
Select Compute to view the following information about the compute nodes in the cluster.
Host |
IP address of the compute node. |
Status |
The value that comes back from VMware. Hover over this for the VMware description. |
Type |
Chassis/Slot |
Serial Number |
vCenter IP |
IP address of the vCenter Server. |
BIOS Version |
vMotion IP |
VMware vMotion network IP address of the compute node. |
