Single cluster view dashboard
On the Dashboard page for a selected cluster, you can view high-level cluster details, including performance, capacity, and compute utilization.
Select the Show Details drop-down menu to view more information about the cluster or select the icon next to a heading for more granular reporting information. You can also move the mouse pointer over graph lines and reporting data to display additional details.
Available details will vary based on your system:
Storage-only system
For a SolidFire storage-based solution, you can view details and performance information specific to your cluster when you select Show Details from the Dashboard page.
| Heading | Description |
Information bar |
This top bar provides a quick overview of the current status of the selected cluster. The bar shows the number of nodes, number of volumes, fault details, real-time statistics about efficiency, and status about the block and metadata capacity. Links from this bar open to the corresponding data in the UI. |
Cluster Details |
Expand the information bar by selecting Show Details to show these values:
Performance |
This graph shows the IOPS and throughput usage. |
Capacity |
This shows the health and fullness of the installation's cluster:
NetApp HCI system overview
For a NetApp HCI-based solution, you can view details and performance information specific to your cluster when you select Show Details from the Dashboard page.
| Heading | Description | ||
Information bar |
This top bar provides a quick overview of the current status of the selected cluster. The bar shows the number of compute and storage nodes, compute status, storage status, number of virtual machines, and number of volumes associated with your NetApp HCI system. Links from this bar open to the corresponding data in the UI. |
Installation Details |
Compute Utilization |
CPU and memory usage are represented in this graph. |
Storage Capacity |
Storage Performance |
IOPS and throughput are represented in this graph. |
