View NetApp HCI storage and compute node details
For NetApp H-series nodes, which comprise a NetApp HCI system, there are two types: compute and storage nodes.
On the Nodes page, the information bar provides a quick overview of the following data:
vCenter IP: IP address of the vCenter Server
MVIP: Management virtual IP address
SVIP: Storage virtual IP address
View information about storage nodes
Select Storage to view the following information about the storage nodes in the cluster.
| Heading | Description |
ID |
System-generated ID for the node. |
Status |
The status of the node:
Type |
Shows the model type of the node. |
Chassis / Slot |
Unique serial number assigned to the chassis and the slot location of the node. |
Serial Number |
Unique serial number assigned to the node. |
Version |
Version of Element software running on each node. |
Management IP |
Management IP address assigned to node for 1GbE or 10GbE network admin tasks. |
Storage IP |
Storage IP address assigned to the node used for iSCSI network discovery and all data network traffic. |
Role |
Identifies what role the node has in the cluster:
Average IOPS Last 30 mins |
Sum of the average number of IOPS executed in the last 30 minutes against all volumes that have this node as their primary. |
Average Throughput Last 30 mins |
Sum of average throughputs executed in the last 30 minutes against all volumes that have this node as their primary. |
Average Latency (µs) Last 30 mins |
The average time in microseconds, as measured over the last 30 minutes, to complete read and write operations to all volumes that have this node as their primary. To report this metric based on active volumes, only non-zero latency values are used. |
View information about compute nodes
Select Compute to view the following information about the compute nodes in the cluster.
IP |
IP address of the compute node. |
vCenter Status |
The value that comes back from VMware. Hover over this for the VMware description. |
Type |
Chassis/Slot |
Serial Number |
vMotion IP |
The VMware vMotion network IP address of the compute node. |
